Simple short term solution #1 - reverse the two output wires from the Duncan neck/Rhythm position pickup.*
Simple short term solution #2 - invest in a Seymour Duncan high output pickup for the bridge/Treble position.
* If doing this, it would be advisable to detach the ground connection for the metal pickup cover. This will invalidate the warranty on a brand new pickup.
Another option is to re-magnetise one of your pickups to the opposite of its present polarity.
In your position, I would leave the guitar as it is for now. Just play on one pickup or the other, never both, until you decide whether one sounds conspicuously better than the other. Only then, decide whether the guitar warrants a second professional quality pickup.
