If you haven't done so already, try increasing the buffer size, and check that the sample rate and bit depth aren't higher than 48kHz and 24-bit. Obviously, increasing the buffer will result in a little more latency, but usually it's tolerable at low-ish buffer sizes.
What buffer size are you running at?
