SOLD - Klein Epic 54 Stratocaster Pick up
HoraceBHoraceB Frets: 337
edited March 2020 in Parts £
These are really lovely pick ups, the only reason I'm selling is because I have replaced with a set of 59's.
Although there are two middle pick ups they are not reverse wound and I had these as a set in my Strat, but there were phase issues with the bridge this is due to the polarity of the magnets but I switched the wires . Here is some info I got from writing to Klein:
The pickups are not RWRP unless the customer ordering them requests RWRP.  In that case, they can be RWRP.  Also pickups wound prior to 1959 had pickups with magnetic north polarity, after 1959 the pickups had magnetic polarity south.   This can cause a phase issue.   A thin sound is an out of phase sound.
Having all 3 pickups from the same year, middle pickup NON RWRP, in this case, yes any pickup can be placed in any position.  When one begins mixing and matching pickups from different years and from different polarities, there can be phase issues.
1954 Epic Middle:  £55 - ppg posted  SOLD
https://www.kleinpickups.com/p-326-1954-epic-series-stratocaster-pickups.aspx
Outputs:  Middle 6.1k
1958 Epic Middle:   £55 - ppg posted SOLD
As stated these are not reverse wound so I used this in the neck position and it sounded gorgeous. Consequently the white wire was extended which I have left .
1965 Epic Bridge:  £55 - ppg posted SOLD
Probably easier if I link for descriptions
 https://www.kleinpickups.com/p-123-1965-epic-series-stratocaster-pickups.aspx
Output Approx:   Bridge 6.4k
