I was lucky to pick up this Korean Ovation Celebrity at the bric-a-brac table at our local church this weekend for £50 - I've given it a good clean and restring, and I doubt whether I'll ever be truly happy with its intonation or the height of its action, but hey, £50.
The previous owner seems to have removed the rosette for some reason, and I figured I would be able to install a replacement myself. But I've done a lot of Googling over the last few days and I'm not really sure what I should buy.
Does anyone have any experience or advice please?
Anyway... as far as I know all Ovation rosettes are the same size, but if in doubt measure the soundhole diameter and the outer edge of the non-faded ring in the finish and you should be able to check if a new one will fit. I did a quick Google too, but most of them seem to be out of stock unfortunately. If you can find one you'll just need to scrape off the remains of the old glue and stick the new one on.
Outer diameter 140mm
Soundhole diameter 105mm
Neck gap 57mm
Any good?
