The method of turning each control until you find the most sensitive spot does actually work though.
It doesn't change the power output, but the EL34 does actually have slightly more gain than the 6L6 - so it increases the volume and reduces the apparent headroom at a given volume control setting. It has a slightly tighter, crunchier sound - although it doesn't make the amp sound like a Marshall, it makes it easier to push it in that direction if you want to.
