custom pickup
I'm looking for someone to make me a Rickenbacker style bass pickup on a standard humbucker base plate.
Something like this (using a bobbin & base plate I have).
The pickup would sit off-centre (ie. the edge along the black sharpie line there).
FYI, it's for a build project I'm doing and the instrument has stock humbucker-sized pickup cutouts already.
Any recommendations in Berkshire?
  • FunkfingersFunkfingers Frets: 14718
    Alegree is probably your nearest port of call. (Guildford.)
    I dare say that, furnished with accurate plan drawings, Ash at Oil City Pickups could program his cutting machine to make a flat lower bobbin plate that would have all of the necessary screw holes in the right places AND conform to regular humbucker baseplate dimensions.
    @Bridgehouse is probably the best person to consult about the joys of the OCP "Overkill" pickup.
  • RolandRoland Frets: 8823
  • prowlaprowla Frets: 4983
    Alegree did a couple of jobs for me before - I wasn't sure if he was selling up and they weren't at the Kempton show this year.
    I would want it to be off centre on the base plate, as the Ric pickup surround doesn't sit directly over the pickup well.
    THINKS: Does the polepiece spacing of a typical RIC bridge position single coil pickup conform to the string spacing of the ‘Berger?
    Yep - exactly.
    (The rough edges on the control bay cover are just the protective film covering the plastic.)
    Are we writing at cross purposes?
    I am unclear whether you require a mounting adapter for the pickup illustrated in your opening post, a rewind/rebuild of that pickup so that it will fit into the existing humbucker-sized orifice in the Spirit bass guitar or the creation from scratch of a bespoke R-inspired pickup?
    The bobbin dimensions of the "bridge" position pickup of my 4001 are 70 x 38mm. (Conveniently, 70mm is also the gap across a Gibson humbucker mounting surround.) Since the 4001 coil must measure less than 70 x 38mm, it follows that its essential parts could be persuaded inside a regular humbucker cover - or a pair of fibreboard plates cut to Gibson humbucker dimensions. The latter would look almost like a small uncovered Jazzmaster pickup.
    If you are going to have the R-style metal pickup surround, you might as well have the bass body routed to accommodate the pickup as it stands. There is even an argument for trying to fit the R-style pickup and surround between the stock bass 'buckers.
    Ultimately, the opinions expressed in this post are just me, running ideas up a flagpole to see whether anyone salutes. They count for nothing - especially if they do not fit in with your plans.
  • AlegreeAlegree Frets: 667
    No, I didn't attend this years show because
    a - I was disappointed with last year's
    b - I didn't have any chance to prepare
    c - no reason to spend time/effort marketing when working at saturation already
    I have already made one of these pickups for a vox bass before.
    Mosrite was the other brand that sprang to mind.
    I've got a bobbin and a humbucker base and I want a full working pickup. :-)
    Unfortunately, I think that routing out a full Ric-size pickup well would take too much out of the Spirit, so I want it to fit into the existing humbucker-sized well.
    The treble surround would just sit on top, for show.
    Cool - thanks for the info!
