I didn't comment as I didn't want to commit myself and potentially give the wrong advice.
Is that 15mm? the presence of two pipes would indicate it is hot and cold water from the boiler, most likely.
If it was gas then I cannot see how that would be allowed or safe.
Do you have a gas cooker?
Either way, get a gas safe registered plumber to take a look.
(Ours was the same when I started looking under units !)
Heating works in all rooms. I have a gas cooker in kitchen. There's nothing on the other side of the wall - it's the outside of the building.
What would be next step with these then? They stick out too far out of the wall and take too much room I need for the dishwasher, otherwise wouldn't be bothered with them. Would they bend a bit if I gave them a knock with a hammer? Safe to do so?
I might just leave it and buy another guitar instead and tell wife we can't afford the dishwasher anymore.
The best thing to do if they’re in the way is to cut them short and fit soldered end caps, so they can be got as close to the wall as possible - but given where they are that will not be easy. You will obviously need to have the heating system drained to do it.
