10 Top PRS....or not?
spark240spark240 Frets: 2083
Further to my question about Rosewood or Ebony fretboards.....the PRS Im looking at has a 10 Top in Charcoal Burst ( with Ebony FB) ...the almost identical guitar with Rosewood and no 10 Top ...I assume standard top is some £400 cheaper..
So...is 10 Top worth it ?
Mac Mini M1
Presonus Studio One V5
 https://twitter.com/spark240
Reddit r/newmusicreview
«13
  • ICBMICBM Frets: 72262
    No.
    The wood costs exactly the same - they don't even know if they're going to be "10"s until the guitar is finished... many of them have "Poss 10" - crossed out if it didn't make the grade - written in the pickup cavity. The grade is defined by the *evenness* of the grain pattern too, not whether it's especially pretty.
    Personally, I don't like them - I prefer more uneven and interesting tops. If you like the particular top, buy it. If you don't, buy one you do - assuming you can afford it, if it's the more expensive one. Don't buy according to whether it passed some irrelevant test, graded by someone else.
    0reaction image LOL 1reaction image Wow! 9reaction image Wisdom
  • prlgmnrprlgmnr Frets: 3971
    ohhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
    now I understand all the times I've gone "eh, what makes that a ten top?"
  • No.
    Certainly not to me anyway. Some of those tops look great but generally, I am so bored with stripey flame or crumpled quilt. Its over-bling! Much prefer plain old linear grain, or even just a solid colour paint job.
    I sometimes think, therefore I am intermittent
  • guitars4youguitars4you Frets: 14195
    A 10 Top is the equivalent of alloy wheels and colour coded bumper + wing mirrors - Adds nothing to the performance but looks nice
  • RockerRocker Frets: 4978
    If you like it, buy it.  Why should the opinions of others affect your buying choices?
    Nil Satis Nisi Optimum
  • HaychHaych Frets: 5616
    A ten top is largely arbitrary and somewhat variable.  IMHO the criteria has softened over time.  A friend of mine has an '88 CU24 with a top that didn't make the grade but would certainly be a 10 top if it was made today.
    Stands to reason, if they can charge more because it's a 10 top then lowering the grade for a ten top suddenly makes your inventory more valuable.
    Turns out there is an H in Haych! ~ Sporky
    Bit of trading feedback here.
  • CollingsCollings Frets: 411
    This is the official definition of a 10 top from PRS:
    "A very small percent of the maple trees cut in North America are actually figured. To make “10-Top” status, a PRS top must have clearly defined figure across its entire top with no “dead” spots. A guitar designated as a 10-Top will usually have a small “10” written or stamped on the back of the headstock in the upper right corner."
  • spark240spark240 Frets: 2083
    Ok...so thats good point..but in this instance Im trying to broaden my knowledge from those maybe more experienced so I can make a more informed purchase at least.
    Mac Mini M1
  • FunkfingersFunkfingers Frets: 14415
    Somewhere in a magazine or book interview, Smith explained that the "10" is just the top ten percent of what was produced over a given time period. Thus, it is possible to get an unremarkable top awarded the 10 or a stunning top that goes unremarked upon.
    BOTTOM LINE #1 - Visually attractive wood grain is no indicator of how the finished instrument will sound.
    BOTTOM LINE #2 - Just as some buyers of used prestige cars expect to get all of the optional extras, some buyers of pre-owned PRS guitars will be swayed by the fancier tops. Thus, a 10 top may help with reselling at a slight premium over other examples of the identical model.
  • DominicDominic Frets: 16085
    It's just a bit of book-matched joinery
    like joinery workshops do every day as a matter of course when making any furniture
    A sheet of veneer laid on board 1.2 m wide by 2.4 m long costs £130 to £180 depending on the wood and cut (that's a lot of guitar tops ie a unit price of about £10 each )
    Selling hamburgers and calling it steak here I think but it looks nicer in a "woody" way
    PRS SE series fancy tops are veneer. S2, Core and Private Stock are solid. The exception amongst US models was the flat-topped EG II series.
  • DrJazzTapDrJazzTap Frets: 2168
    As an owner of a 10 top, I say no. You pay over the odds and it makes me feel like a bit of a bellend pulling out a flashy flame maple topped guitar.
    The “9 and a half top” (Poss 10 crossed out ;) ) I had was plenty flashy enough... although that was partly because it was pink. I only ever used it at big gigs, where it looked less bellendish than it would have in a little bar :).
  • 10 top owner here and I say no unless there is something else about that guitar you prefer.  Better weight, nicer neck or sounds better.  I have mine because the neck and fingerboard are nice.
    As for looking like a bellend, once that sweet music leaves your fingertips to poke the audience in the earholes, they will not care what your guitar looks like.
    C'mon, the only audience members who care about what your guitar looks like are other guitarists!
  • WhitecatWhitecat Frets: 5407
    10-tops are the second worst grade of figured top available from PRS...
  • RaymondLinRaymondLin Frets: 11860
    Private stock, Wood library, Artist Pack, 10 top, regular.
    did I miss one?
    did I miss one?
    Wood Library isn’t a grade unto itself but that’s otherwise about right. There are “opaque” graded tops too below the “regular” level but as the name implies those are only used for opaque colours.
    did I miss one?
    Wood Library does not refer to the grade of wood, it is the conbination of woods that are different from the normal core line.
    My 10 top is on a Wood Library guitar which has a maple neck rather than the usual mahogany.
    Only four grades as far as I am aware.
  • PRS SE series fancy tops are veneer. S2, Core and Private Stock are solid. The exception amongst US models was the flat-topped EG II series.
    Better yet - they usually are a high quality veneer on top of a chunk of maple... which is then on mahogany etc
    Whether it is a solid flame maple top or a veneer on a solid maple top, it'll sound the same.
    This is my FGN with a veneer ontop of a solid chunk of maple:
    Guitar(s): Custom Gordon Smith Graduate, FGN Odyssey JOS-FM-M FBT, Ibanez RG6PCMLTD, Yamaha Pacifica 311H, Harley Benton Fusion Pro HSH Amp: Blackstar HT5-R MKII, Presonus Eris E4.5 Active Studio Monitor Speakers  | Effects: Wampler Plexi Drive Deluxe, Fender Marine Layer Reverb, Fender The Bends Compressor, TC Electronics Flashback 2, EH Hum Debugger, TC Electronic Polytone 3.
