When to mic drums?
Hi All, We are playing on stage in a large hall, circa 200 people. mainly xmas songs, slade wizards etc. we have 3 vocals bass and guitars going through a 1200 watt PA. https://ibb.co/5ht0ZFT
Do you think we need to mic the drums to? I think we do but a.) we haven't played this type of venue before and b.) we are on a budget!
Can we get away without mic'ed drums what do you think?
  • I'd say your PA is too small for that all, and wouldn't put drums in it.
    R.
    Rule of thumb - when it's not your PA, and not your sound guy ;)
    IMHO you could put a kick drum mic, and coincident pair (well) over the drummer's head, but no more
    Feedback
  • ICBMICBM Frets: 72320
    Does the PA have subs? If no, don't even put the kick drum through it, let alone the whole kit. It will mess up the mix for the rest of the instruments and might even overload the speakers. In fact, if it doesn't then it's probably too small for that space anyway. If it does have subs, then put the minimum amount of drums - especially kick - that you can through it to fill out the sound rather than trying to get the PA above the level of the kit itself.
    Quality is always more important than volume. Always.
  • In an ideal world I’m a fan of micing everything (at least if I’m not manning the desk!). That means all drums and amps. Not for added volume, but just to control everything and get the right mix at the lowest volume possible. It also helps you keep stage volume as low as possible, which is usually a good way to a good overall sound and better performance.
  • Yes it’s a peavy pro 15 speakers with tops and subs. The reason we got them was to improve the sound and get a good balance rather than volume.
  • For 200 people in a hall, yes. Absolutely you must mic the drums.
    Bye!
    He's got a 1200 watt PA - too small for that hall. Putting drums through it would be self-defeating. Need a bigger PA, or play quietly.
    Didn't say whether his equipment was good enough or not.
    Bye!
  • John_PJohn_P Frets: 2750
    In that room with 200 people you need a bigger PA and mics on everything imo.
    I would suggest you hire in a local engineer with their gear and just enjoy playing.
    I've done many a gig in a room that size with 2 SRM450's and a couple of subs . Personally I would mic everything but being mic'ed doesn't mean you have to use it, just means it's there if you do need it. Watt's don't mean a great deal when it comes to PA .... the large HK linear pro rig we own and hire out is only actually 400 watt tops with 500 watt bins but it's deafening and more than capable of serving 300 people outside. Conversely I repaired a set of 600 Watt Alto's a couple of weeks ago and they couldn't produce anything like the SPL the 400 Watt HK tops could. To know how loud a PA is you need to know it;s SPL and angle of coverage ... Watt's don't tell you a great deal really ... specially these days when even brands like JBL are selling 120 Watt active speakers as 300 watts RMS
    The mistake people make with mic'ing drums and putting other wild transient and low frequency instruments into a PA is not processing the signals. High pass filters and compression can make life a lot easier for the PA and result in a cleaner sound and less failure of gear. With this in mind the type of desk you use is more important than the type of PA when it comes to mic'ing everything
  • As a general rule, if I have subs I always stick a mic in the kick. I then add hat and snare (in that order) if I can. In your case to give you a bit of extra room in the PA I would take the bass guitar out of the PA and put the kick in it
    www.maltingsaudio.co.uk
  • octatonicoctatonic Frets: 33793
    This. ^^^
  • You (@Danny1969  and @octatonic ) are speaking with the benefit of experience and expertise in this field. The OP is clearly inexperienced. He has a PA adequate for a smaller venue and is playing in a largish Hall. What we might do with compression and eq is probably beyond what he is capable of at the moment.
    Not sure what else to say - I'd stick to minimal instruments in the PA, keep the volume down, and watch the bottom end.
    Failing that, where are you, and what's your budget? I could pop down with my rig :) (unlikely to be viable as I'm in York)
    R.
    I'm not sure about that. I've played a hall at least that big with a PA smaller than that - 1150W (750W through 1x12" + horn tops, 400W through 1x15" subs), plus adequate backline (50W 1x12" valve guitar amp and 250W 1x15" bass amp) - and it was fine. The kit was mic'ed with one on the kick and an overhead. I wouldn't have said we were quiet either, the guitar amp was up at the point of power stage overdrive and sounded great... couldn't have gone any louder, but it was limited by vocal feedback as much as available power anyway.
    You too have the benefit of knowing what you're doing :)
    It is easier than people think it is.
    The most complex thing is ringing out the room and you just need a graphic EQ for that.
    It takes 10 mins max and you can learn how to do it by a youtube video.
  • kennedydream1980kennedydream1980 Frets: 1156
    edited December 2019
    I always mic the kick drum regardless of the venue, as once the band kicks in it will get lost. If the venue doesn't call for a mic on every drum then I won't go for that, sometimes it's overkill. However I always put a condenser mic up as an overhead to capture the rest of the kit, in some venues this is a far better solution. In really small venues this might not be on through the FOH speakers, in that situation it's only there so everyone can hear the kit through their IEM's.
    With regards the venue posted by the OP, that looks like a typical village hall type setup which will carry the sound really well. I would think you could get away with a mic on the kick and an overhead and it will sound fine.
  • On the subject of 'ringing' a room I've found a pink noise generator on eBay for about £20 but can anyone suggest an RTA mic?  The cheapest I can see are around £69.  Is there anything worth having for less?  Alternatively, can you recommend something worth picking up on the s/h market?  I struggle with singers who a) often don't arrive until you have ten minutes to go and b) if they manage to get to a soundcheck don't use their mics/voices anything like they would when singing..
    On another topic related to the post, what's the secret of mixing the kick drum and not getting a load of bleed from the floor wedges which, in a typical gig, are about 6ft away.
  • MusicwolfMusicwolf Frets: 3654
    Behringer ECM800 for around £30.  I have one and they would do the job in a live situation.
    This is exactly what the ECM8000 is designed for, particularly with the Behringer UltraCurve Pro DEQ2496.
    They work well.
    R.
