my late-70s Strat's original pickups were crudely wax-potted by a previous owner - I think he just melted up a red Christmas candle, not even made of proper wax, and dumped the pickups in. How can I get the stuff - or at least some of it - off without destroying the pickups?
To add some background, I took them out and replaced them with vintage-spec staggered Duncans some 20 years ago to make the guitar sound more like a proper Strat, but inspired by
@p90fool 's recent NGD thread I think I may want to put them back and give them another go (at least the neck and middle one, I'll stick with the Tele pickup that's in the bridge position).
Edit: tagged someone else as the recent purchaser of a 70s Strat by mistake
One hundred per cent wax removal is impossible. Hopefully, the red wax job is sufficiently bad that it did not penetrate the coil very deeply and can be extracted.
I'd probably try putting them on a hot radiator for a bit to see what happens.
Something to soak in up, absorbant paper?
Good call. I should have thought of that I have an ancient hairdryer in my tool kit exactly for this kind of thing.
Should wick to the paper.
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
That said, Little Feat are great!
https://imgur.com/Smo73UK
https://imgur.com/NA7EAOx
Well, actually, I still can't post pics, despite re-reading the instructions on here. So frustrating!
If it is right into the wire then it won't matter.
Given that they're nothing special, it's probably best to either live with them as they are or save time and just bin them...
+1 to what ICBM said though, not the binning them , but rather not getting too obsessed as they aren't old 70s ones.
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
This site https://www.strat-central.com/70sstrats/index.htm#specs dates the serial number (S 869649) to 1978, but the fully shielded pickguard and pickups would date it to 1980. One of the pots which is out of the guitar has a 1978 number. Won't take the neck off to check the stamp but if the serial is '78 the neck stamp is likely to be the same ... I've read somewhere that lefties were just thrown together from what they had lying around and thus often have parts from various years. So I have a 1978-80 factory partscaster perhaps.
Do you know what exactly is different between 70s and 1980 spec pickups? This is purely out of interest, the guitar has been bastardised beyond all recognition (it was sunburst until I took off the finish a few years ago) and I'm not selling it anyway.
I think the earliest they could be is a set from a 'The Strat', from 1980-81 - they had plastic-bobbin pickups with the bridge being the slightly hotter X-1, with a yellow wire. As far as I know those pickups weren't used on the standard Strat though.
https://imgur.com/6AlZuvP
not much to see with the wax still on them, but the bridge PU (in the middle)does have a yellow wire
Wiz duly awarded to ICBM.
They may have been potted for a reason, but lots of things were being done in the 80s for reasons that, from today's perspective, weren't very good reasons.
I haven't got sufficient experience to know whether unpotted pickups really sound more open etc. than potted ones (for lefties, it's always difficult to just check out stuff) and I wouldn't expect any magic transformation to occur just because of the removal of a bit of wax from a run-of-the-mill pickup.
Whether wax affects the sound of a pickup at all is an entirely different, and irrelevant, can of worms, but you're not going to end up with an unpotted pickup regardless. I'm afraid this is a futile endeavour for you.
