For example, the tidy way to connect each coil split ground is to the chassis of the same pot chassis as the respective DPDT switch.
The pot chassis grounds should be linked to each other.
Finally, a ground wire needs to run from your volume pot chassis to the ground terminal of the output jack socket.
The connections from the bridge/Treble position humbucker look wrong. Pulling up the push-pull pot knob fails to remove its stud (North) coil from circuit. Instead, it creates a parallel loop
The grounds are all soldered to the "TONE" pot chassis as per the diagram where the Cap is to be grounded
An outside possibility if you've done that is that when you bent the volume pot ground terminal back to solder it to the casing, you strained the rivetting to the track board - that will result in the volume control only making a small difference as you turn it down. If so, you can fix it by firmly clenching it back to the trackboard using a pair of narrow-nose pliers.
You can test which of these it is without taking the guitar apart - simply get the cut-off end of a plain guitar string, and wrap it around the shafts of both pots under the knobs. If the volume control now works properly, you just need a ground wire between the pots. If it doesn't, the terminal has lifted.
Put a capo on the 1st fret, slacken the strings and remove the neck. Then you can take the pickguard off, fix the problem and reassemble keeping the strings.
I think this might be a problem then?
So I found the issue to be a poor connection coming from the volume pot to the ground,
however when I touch the bridge I get a buzz sound, is this normal? video below:
