Oooh, I like the sound of that! Never having done something similar, Im guessing that it is certainly possible.
A Tele would make it easier (flat surface, no compound curves) - especially if you don't mind it not wrapping over the edge. I suspect the way to do it would be to strip back old finish, ensure surface prep is spot on, treat the paper as a veneer and use a heat-sensitive adhesive (like hot hide glue) and iron to apply to give a flat surface. Then spray gloss nitro over the top.
Good luck
Adam
Have a looksee on youtube, you can transfer the image to the wood and rub off the paper if you want.
http://www.thefretboard.co.uk/discussion/61134/sarge/p1
Has anyone used it and applied any paint over it - my thought being to 'burst' around the edge with a spray can to hide the join. I take it that you *should* be able to as folks have used lacquer over the top. However, will nitro work?
That wrapping paper is likely to get pretty fragile once wet with mod podge so you'll need to be careful.....perhaps iron the creases out where its been folded first.....
Im pretty sure mod lodge is PVA or very similar
