New member, so apologies if this has been discussed elsewhere.
I have(had) a MIM fender '72 tele custom & replaced the body with a warmoth generic tele body some years ago.
I'd like to put a 'proper' '72 tele custom body back on & warmoth is my first port of call as I'm 100% it will fit with no issue, but once import duties shipping & VAT is added it can get costly.
So I just wanted to reach out & see if there were any UK sources where I could get a body of similar quality.
Unfinished alder or mahogany, three bolt microtilt neck, & I have a SD phat cat in the neck at present so a gibson HB pup rout will suffice (ie no need for a widerange rout) & I have a wd scratchplate with a gibson humbucker slot which I intend to use.
Belly & forearm cuts would be nice too
I have contacted guitarbuild uk, but they really haven't been helpful in addressing specs their comms, (issues being 3 bolt neck rout seems to be exclusive to strat neck pockets & the position of their neck pup routs).
I think I'll probably go for warmoth, but before I do I just thought I'd ask here & see if anyone can point me in the right direction.
Thanks & happy new year
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/202865802573
I don't want another MIM guitar, I don't like the thick finish or multi piece bodies on mexican fenders
I've upgraded the saddles, tuners, installed seymour duncans , wire wooled the finish on the back of the neck.
I want a body that accomodates the 72 style layout with 2 tone & volume & 3 way toggle on the upper horn & then finish myself, solid or transparent depending on how nice the wood looks
& they only seem to offer the 3 bolt system in a strat pocket, when I sent them my specs they just sent me towards their 'custom build' page which again doesn't offer the 3 bolt in a tele pocket.
You can't send custom bodies back, so whilst it may seem the best option without this being cleared up I'm reluctant to gamble
I had a look through my stash of bodies but I only have swamp Ash routed for 4 bolt and Wide range size humbuckers as I was going to say if you give me the dimensions I could scale them off as that is a Guitarbuild body.
Or as said find a UK luthier who can build it for you, as technically what you want is going to be custom order.
What you're asking for would be no real problem for Luther in the UK to do. As you're asking for non standard routing they will most likely ask you to send the existing body and neck to make sure everything is in the right place and fits perfectly.
Sorry I can't help you with this as my workshops out of action until at least the second week in February.
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
