Pub gigs, parties, beer festivals - We only put vocals through FOH PA and occasionaly mic the kick drum if weve got the sub cab with us. Two 50W tube amps are plenty loud enough.
But have been thinking it would be nice to put a BIT of each guitar through FOH just to blend and balance all the way at the back of the room, you know past the throngs and hordes of crazy sweaty fans.
Always put off by setup time and faff and more delicate mic gear to worry about. Anyone got a quick easy robust cab mic method they use for smaller gigs?
ps DI is not an option.
E609 mic with raw cable threaded through the amp handle so it sits in line with the white mark.
The E609 is flat faced so no need for a mic stand.
Mic'ing isn't really about volume (except at big gigs) it's more about even spread for the punters and protecting your hearing. Without mic'ing the amps need to be louder on stage to be heard over the drums by the punters ... and your standing 2 metres in front of those amps. It's not good for your ears really
but the point of me running wet/dry is to get more spread in a live setting
You ideally want something that can sit flat to the grill cloth.
Problem with draping thru handle is i run a zilla 2x12 so the handle is in line between the two speakers. And recently ive run it as a vertical cab so no handle at all on the side.
Anyone use one of this cab grabbers?
If you don't mind screwing a plate onto your cab, the ampclamp is good: https://ampclamp.co.uk/shop/microphone-brackets/wt-pro/
R.
Eqd Speaker Cranker clone
It is more than just off axis- it is a full 90 degrees to the speaker, pointing at the floor.
I've done it too, but the e609 is a better mic to do this.
I recently got a Palmer PDI-09 to add a DI for my amps and it sounds fine and is less fiddly to set up than a mic.
Much better to do the 609 draped across the front thing.
The difference between the two is significant. The 609 sounds scooped and harsh in comparison. The 906 just instantly sounds like my amp. Try them together if possible.... the 906 is a much flatter, more accurate, smoother sounding mic. Definitely worth the extra cash. With the 906 I drape it through the handle, positioned just outside the dustcap. I take an XLR to the mixer. No effects, comp, nothing except a HPF at 80Hz. The 3 position switch could be useful in other situations I guess, but I just use it flat. Could not be happier.
I was going to sell the 609 but a bandmate wanted to use it.
I agree that the purpose of a mic on an amp is for spread rather than more volume. It's so that the screaming sweaty fans at the sides and back can hear you just as well as the ones right at the front.
R.
The e906 is smoother sounding and the switches give you more options.
So much less hassle than a mic, needs no power and takes an XLR to the desk just as you would with a mic so I don't understand why it wouldn't be an option?
Something IR-based - like the Mooer Radar, for example - sounds significantly better with the right choice of IR, but still nowhere near as good as the real thing.
For a mic alternative...the Superlux PRA628 mk II from Thomann is an astonishingly good mic. Position it right, and it sounds excellent (not just good for the money), and being super-cardioid the off-axis rejection is perfect for a noisy stage.
I've just ordered a redbox and was going to post to ask of its OK to leave it permanently on circuit. You've just answered my question.
