Not done a pub band gig for £250 since about 1995 I think, that's more like duo money .
Not in it for the money but need a bit of cash to keep us in guitar strings and plectrums.
So you ask £400 ish for a special event?
We'll also do a straightforward, very local birthday party for £400-500, and weddings are £650-750 for the simple reason that they are always more hassle and I don't like doing them.
We don't charge proper function band money for wedding because we're not one, although we do play for 2.5-3 hours.
I'm conscious of giving good value, but refuse to be messed around any more. I doubled the price for weddings two years ago just so I could avoid doing them but it's had the opposite effect and that's now what we mainly do, though we get far fewer Bridezillas than we used to when we were too cheap.
What’s the venue? Hotels usually want to see insurance certificates and PAT records. Back gardens usually have inadequate power supply or shelter from rain. Other venues sit in between. If it’s a distance to travel then you will need to think about travel costs and possibly accommodation. Is there a disco that we have to work with? Do you expect to use a mic for speeches? What song do you want for a first dance?
Get to venue around 11 in the morning, could be a 10 minute drive, could be 2 hours. Find out who's in charge, where's the band going etc. Set up and soundcheck while the staff are setting out tables, generally this takes 90 mins to 2 hours depending on how brutal the load in is. We've fortunate enough to be in a position to charge enough money to cover our own sound and lighting engineers but it does mean we load in a huge amount of kit. Doing your own sound at a wedding can be challenging in some venues due to the odd buildings you encounter. You may also encounter sound limiters, lack of space, unearthed generators, leaky and cold marquees, mud trenched fields, lack of parking.
Once all done then turn the gear off, leave the venue and go back home or if too far to go back home go and amuse ourselves in town.
Then back around 7pm suited up, start playing around 8 ... do 3 x 45 min sets with 20 minute breaks. then let the DJ finish the last half hour or so. Then break down, load out and by now it's always around 1am. Could be 2 hours drive to get home but most of the time it's 40 minutes or so. Most of the wedding venues we do tend to be posh country houses and hotels in the country so there's often some tricky roads.
So it's a bit different to doing a pub gig, it can take a very large chunk out of your day and the whole evening until the early hours. It's worth a couple of hundred each at least I would say
