I have a Strat neck finished in Tru Oil.
I painstakingly removed the Tru Oil finish off the surface of the headstock (took 1/2mm thickness off) and then applied an acrylic spray lacquer. In retrospect, there was obviously some tru oil remaining - the solvent in the lacquer reacted with the tru oil and resulted in this rather unflattering fishscale appearance...
[Imgur](https://i.imgur.com/5HRqFCp.jpg)
Fortunately the whole thing dissolved off with nail polish remover. I have now re-applied tru oil and wish to apply a Rothko and Frost waterslide decal.
[Imgur](https://i.imgur.com/eMuQd8S.jpg)
The official position is that most decals are not compatible with Tru Oil, but apparently the problem involves the manual handling involved whilst applying the oil - and doing so as an aerosol would result in a good result.
Tru Oil Aerosol doesn’t seem to be available though. How do I go about this please?
Expert opinions deeply appreciated
1. So you tru oil the headstock.
2. You spray a layer of polyurethane varnish over the tru oiled headstock
3. Apply the decal - allow to dry
4. You spray another layer of polyurethane varnish over the dried decal
5. Then continue with multiple coats of Tru Oil...
Would that be correct?
