A while ago I started a thread criticising the quality of the plating on gold hardware for tarnishing very quickly. Admittedly it’s an issue that other types of hardware don’t seem to suffer from in the same way.
The guitar in question is a rather expensive Gibson signature model and I haven’t used it very much in all honesty.
However, I also notice that the frets on this particular guitar oxidise very quickly compared to other guitars I have, which also get the same amount of use and which also stay in their case when not being used.
That begs the question, could the case be responsible for the hardware and the frets tarnishing/oxidising so quickly?
There's a large pouch of silica gel in the case which hopefully keeps moisture under control but could there be some kind of chemical additive or treatment applied to the case lining during manufacture that's attacking the metal parts?
I put new strings on about a week ago and polished the frets at the same time but they've already started oxidising quite a lot - certainly far more significantly than they should in a week!
I've had the guitar a couple of years now so I doubt I could put in a warranty claim in any case (no pun intended) but it would be a shame if the one thing designed to protect the guitar was actually damaging it.
Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
I also wonder if nitrocellulose lacquer might, if it's not fully hardened... it's not far off the same chemical material.
If it's neither of those it does sound like glue in the case lining is a strong possibility, unless the case has been stored somewhere damp and the lining has absorbed moisture. Have you checked the silica gel is dry?
It is finished in nitro, though, and the same thought occurred to me when you mentioned the celluloid previously, however, the finish seems alright in as much as it doesn't seem soft and there're no areas that seem 'off', although I do appreciate that even modern finishes can take years to show signs of problems.
The case and silica gel is bone dry, always has been and I'm very careful about where I leave the guitar whether it's in the case or not.
If it is the glue used to make the case is there anything that can be done apart from buying a new case? Leave it open in a warm environment for a few weeks/months or is it basically gonna be like this for eternity?
Not saying that's definitely the issue, but I'm still removing my Gibsons from their cases immediately after a gig as even Elixir strings can feel "grippy" the following morning if I leave them in the case overnight.
I kind of accept the gold hardware oxidising, it always seems to even though I don’t have particularly acid sweat or anything (based on how long my strings seem to last) but it’s disappointing that the frets oxidise the way they do.
Richlite is made from phenolic resin, I don't know if that could emit some sort of corrosive vapour.
Sorry . No offence intended, but this is exactly the pattern of corrosion you see on guitars owned by people with slightly acidic sweat.
The tarnished areas are only in the places you would touch it when you're playing or tuning it - the neck pickup shows this perfectly, the strings have protected the areas under them, and the raised end of the fingerboard has kept your hand away from the pickup on that side. The machinehead keys - but not the main casings of them - the edges of the bridge pickup, the bridge itself and the bass-side tailpiece stud all show it too. The case lining over the strings will also have absorbed sweat from the strings when you put the guitar away.
Why this guitar should be more prone to the frets corroding than your other ones may just be down to the exact grade of nickel-silver that's used, different manufacturers use different types.
It’s a rosewood fretboard...
It doesn’t have a silica gel pack in there. Could mine be a simple moisture issue?
Heres mine with a telecaster for fret colour comparison:
https://imgur.com/gallery/B4xZfEm
This guitar doesn’t get used as I’ve had other SGs.
Edit: and the bridge itself for that matter, to which my right hand is anchored is largely untouched by any oxidisation.
The machinehead keys are a major giveaway - they're definitely not in contact with the case lining at all, and it's only the faces of the keys that are affected - if it was something to do with a vapour then the rest of them would be equally tarnished.
