I have recently got a HX stomp and I’m very pleased with it.
Most of the time I will use it as a multi fx on a simple board:
polytune mini > revival drive compact > Greer light speed > HX Stomp
into the front of a 50w Top Hat Emplexador into 8ohm 2x12 with a vintage 30 and g12H 70th anniversary.
All wired up with evidence audio SIS cables. 6ft lead to the board, 10ft lead to the amp, Van damme cable and neutrik plugs.
So eventually to the point - the sound of guitar into the amp is brilliant, and sounds the same with the revival drive, poly tune and lightspeed in the chain. When the HX stomp is in line too there is a loss of vibrancy and sparkle to the sound which I wonder is some kind of impedance issue?
Stomp is set to auto impedance, would altering this help? Any tips?
I don’t think a buffer before would help as the revival drive is buffered bypass but would a buffer after help?
I have had a play with the global eq on the stomp so maybe I just need to keep tweaking this?
If the Bright Onion doesn't fix or at least identify the problem...
Do you have access to, or would be willing to buy to test it, a loop-switcher with adjustable levels, such as a Boss LS-2? If you do, put the HX in the loop and adjust the level carefully until you're certain there is no change in volume when you bypass the loop, then see whether there's still a tone change.
I have got a spare Boss CS3 compressor/sustainer. I’m sure I read somewhere that Boss compacts are buffered bypass and that the buffer sounds decent, is this right? Just wanted to know if I could use the Boss as an initial test on the effect of a buffer before I rip the other board apart to get the bright onion switcher!
Auto impedance means that the impedance will depend on what you have in your first block. This might help https://www.thegearpage.net/board/index.php?threads/so-this-helix-impedance-crap.1967794/#post-26983042
Note - I have a full fat Helix not a stomp, so I'm assuming that this is true for the stomp!
You really do need to try it with something where you can adjust the level while switching it in and out of the circuit.
