It's a remarkably hard sound to duplicate - a strange combination of a fixed wah and an oddly 'harmonic' overdrive. The original recording was done with a random mic placement on a Laney combo, and a Morley wah pedal. ecc83 is right that apparently they couldn't reproduce the sound when they later tried.
https://www.toontrack.com/news/the-money-for-nothing-tone/
Try a Boss Metal Zone starting with the distortion fairly low, the bass and treble turned off, the mid full up and play around with the mid frequency - it's a long time since I used one but I think I managed to get something similar like that.
If the Boss is too expensive, Behringer make a copy - the Ultra Metal. Which is probably the pinkest thing ever made after 1990 .
I believe another key part of MK’s sound on that song is having a wah pedal before the drive, with the treadle rocked back a bit for a more nasal sound. Bit of experimentation and you should get a fair approximation of the sound.
Facebook: @northernstomps // Instagram: @northernstomps // Twitter: @northernstomps
Specialist Retailer Of Handmade British Stompboxes // https://www.northernstomps.com/
Currently Stocking: Hudson Electronic/Raygun FX/Zander Circuitry/ThorpyFX/Rainger FX/Life is Unfair/ Magnetic Effects/Fredric Effects
Gain pedal, light distortion and a crybaby wah. Takes some experimenting with the wah to find the correct static position.
if you wanted to get this sound out of 1 cheap pedal, I think the closest you’ll get is a Boss DS-2, which has the right type of breakup but also a nice mid boost.
I heard that he didn’t use a wah, and that it’s a cranked fender tweed, but he used a wah to recreate it live.
Nil Satis Nisi Optimum
