Feedback
I had an old Denon amp which did exactly as you describe, but I never got to the bottom of it - sorry. I just put it down to a failed power transistor on one channel, and very luckily inherited a rather nice Technics amp at the same time.
I'm not going to page the resident amp guru as I don't want to mither, but I wonder if he does chance in here, he might have an angle?
If that sounds like a pain in the backside to troubleshoot, it probably is - the easiest way is to change every electrolytic cap in the thing, but there are often rather a lot in hi-fi amps... and even then it might be something else.
Hope you get things sorted.
In case you don't & are looking for an affordable solution, I have a working (when retired) Sherwood Newcastle R-125 that you can have for free. The only issue is that the P&P might be more than it's worth
Comment away
Now on to the next conundrum - I bought a CD the other day before realising I no longer have a CD deck.
Can you cure stupidity by replacing old electrolytic caps?
