Gigrig Virtual Battery issue / question
soma1975soma1975 Frets: 6683
edited January 2020 in FX
If I measure the output with a multimeter and turn the trimpot either up or down the voltage remains constant. Does that suggest my trim pot is buggered?
Or does it only do its thing when plugged in or something?
  • KeefyKeefy Frets: 2285
    If it uses a voltage regulator then it probably won’t change until you draw some current through a load.
  • soma1975soma1975 Frets: 6683
    Cheers. Probably best off to just twiddle it while plugged in then and listen to if it sounds different
