Solderless Telecaster harness?
I’m about to buy a few more parts (well, most in truth...) to put together a Tele partscaster. I’ve had a few bad experiences with my own inept soldering and wondered if there are any disadvantages to solder less harnesses on eBay, etc? Look relatively simple but are there drawbacks?
  • phil_bphil_b Frets: 2010
    if you don't use solder then you need a connector.
    drawback 1 extra cost
    drawback 2 extra bulk
  • ICBMICBM Frets: 72307
    drawback 3 long-term reliability issues
  • FunkfingersFunkfingers Frets: 14423
    Drawback #4 - They come with EMG pickups. Ho-ho! ;)
    In all seriousness, I am enormously fond of the EMG-FT pickup. I do not rate the EMG-RT at all. It is, basically, an EMG-SA in a Telecaster-shaped plastic housing. Sounds nothing like a proper Telecaster.
    Either practice soldering until you are confident in your abilities or pay a professional tech to do the job for you.
  • scarry67scarry67 Frets: 143
    Ah, sounds like the trade route may be the wise one then.
    Or even “trad”. Bloody predictive text
  • KingSubKingSub Frets: 42
    I can solder quite well, but in the spirit of experimentation I've bought an EMG T set for my current build. Came with the solder less cables and connectors.
    I'll report back when it's fitted and tested.
    To be fair it all looks pretty neat and robust.
