Hi guys,
Tempted to take both my 1x12's to the gig tonight. Both are 8ohm, so is it basically just a case of setting my amp to 4ohm output with both connected?
Also....one houses a Creamback, and the other is a Badcat speaker which I believe is a V30 (ish)?
If I decide to stack them, which would you suggest is top and which on the bottom?
Cheers
Keir
Which model is the Creamback? If it's the G12M-65 I would definitely put it on top, but if it's the G12H-75 I would probably put it on the bottom.
