Fitting a Bigsby to an SG
Has anyone put a Bigsby on an SG?  Recommended or not? How difficult to do?
Thanks.
  • ICBMICBM Frets: 72922
    The easiest and best method is to use a Vibramate - it not only involves no drilling or permanent modification, it also raises the Bigsby slightly so it produces a better break angle over the saddles and under the tension bar so it causes less tuning issues.
    The only disadvantages are that it restricts you to the expensive US-made B5 - the cheaper far-east-made versions don't fit - and even though there is no drilling, it can leave pressure marks in the finish if you do ever take it off again.
  • TheMarlinTheMarlin Frets: 8075
    Yup. What he said.
