can you test pots and pickups ....
can you test pots and pickups whilst they are out of a guitar? using a meter.
I have some old stuff
  • ICBMICBM Frets: 72815
    Yes.
    You will need a meter that reads resistance in the 20K range for pickups (typically 5K-16K) and the 2M range for pots (typically 250K or 500K).
  • axisusaxisus Frets: 28348
    ICBM said:
    Yes.
    Ta. I'll give it a whirl when I get home tonight.
  • FunkfingersFunkfingers Frets: 14632
    One word of caution. Pickups have occasionally been known to give no reading but still work perfectly. The bridge/Treble pickup of Roy Bunchanan's 1953 Telecaster, Nancy, springs to mind.
    https://www.tdpri.com/threads/roy-buchanans-53-nancy-tele-final-secret-revealed-itself.258726/page-2
    No, that's a perfect example of a broken pickup. Horribly thin, shrill, grating, ice-picky and unmusical-sounding... that's what it sounds like when you have a pickup with a coil break at the ground end.
    And that's before you get on to his playing ;).
