On crossover look for protection fuses ... these are often 24V bulbs used as current limiters. If these are open circuit replace with similar
Also look for blown ceramic resistors .... normally these are large and coated with white fire proof ceramic coating
Check wires from cross over to input connector
Many thanks for a quick and detailed response.
Sadly - it is as I feared it might be ... I honestly don't have much idea what that technical talk means and I don't have the basic equipment to test anything. Oh boy.
I can see for someone that has a few basic tools and kit such work may be common place.
Given that I don't, I'm wondering if:
a] would it be worth spending money on a repair given that they are modest price items in the first place?
b] are they saleable as a pair when one doesn't work?
[ side note: I bought as a bit of an experiement to see if I could do without an amp in a small bedroom and just use a multi-fx and a mixer. That experiemnt is on-going and I'm considering a non-powered mixer with a pair of active monitor speakers I have. ]
The first thing to do is take the jack panel off - just four screws - and see if you can see a detached wire.
Thanks a lot. The speaker is totally silent, no buzz, hiss or similar when connected.
I took the panel off - black and red wires all nicely secure in their positions. I couldn't see very well inside. I gently took hold of the black, red, green and blue wires, all gave resistance when slowly pulled so that may indicate each is also properly attached - but I couldn't see or be certain.
How do I actually get fully in? Should I even try to get in to look? Do I need to unscrew the corner mountings and more?
Thanks again. Earlier on I took those two screws out, the grille seemed tight in and I didn't want to yank it if it was not supposed to come out with just those removed. I'll give it a go. Should I take the jack panel off and feed it through the hole when I lift the bass driver out?
There's probably enough slack in the wires to lift the bass driver, and if they're too short to get any more access, disconnect them from the speaker - they'll most likely be just push-connectors. Make sure you note which way round they go if it isn't obvious or labelled.
Good work. It can be important to check the really basic stuff before disassembling the wrong thing . Speaking from experience .
The cable indeed.
OMG I am such a plonker.
I took it all apart as advised. All looked fine. Everything was secure and connected. It gave me a chance to clean out some of the dust and fluff etc at least. So I thought well, let's look at the other, compare, and take the opportunity to clean that one inside too. A little more dust and fluff etc. Both looked fine and just the same.
So, I thinks - surely it's worth another try, switch things around. Lo and behold. Using the first cable neither speaker worked from either output socket. Using the second cable both speakers worked from both output sockets.
OMG and bloody hell. It was only the flipping cable that was faulty!
I simply took the seller at their word that the speaker was blown and din't even think to take it right back to basics of checking cables, connections etc. I was told that only one speaker worked and didn't think beyond it.
There's a lesson to learn eh!
Still - it seems I may have benefited more than just learning a little lesson.
All's well that ends well.
Thanks so much everyone @Danny1969 @ICBM @steamabacus for chippinng in with your advice.
