Might require careful balancing to avoid feedback though.
Just because you're paranoid, don't mean they're not after youI'm looking at buying a new desk, but ones with 2 x AUX sends are way more expensive than ones with one.
Good call on using another out for the FOH clone, i would think CTRL RM OUT would work for this in theory right ?
You can get a 14 channel Mackie with 2 Aux sends for about £200.
Or get the Behringer MA400 for £20 ..... then the singers vocal plugs into that and then the pass thru socket goes to the desk. This means he can set up his vocal level independently of the desk
for the MA400 - (forgive my ignorance I'm new to PA stuff) can the singer take a headphone feed from that as a IEM source separate from the main feed which goes to the desk as normal ?
IMoltisanti said: I've done a sophisticated drawing for you :0
Basically in this setup singer can have mon feed from desk but independent vocal level
OK so the singer is getting the MON mix + their own vocal in the IEMs with independent volumes, and the desk gets the mic signal as normal. That sounds like a great solution that i totally hadn't considered, thanks!
*Very important point*
Any solution which doesn't involve don't kind of EQ and audio limiting is a very efficient way to permanently destroy your hearing.
I've been on IEM's for nearly ten years ...... just keep the volume down and don't insert them until everything is up and running. Then you won't be under any more risk than using them on an ipod. Basically mix down, not up !
1) Of course you can limit a headphone amp, you just can't accurately predict the numbers without the further info described. You can, however, give it a good go by ear.
2 )Mastered music played on an iPod, etc. has normally been limited at several stages in the process. As a result there is usually little dynamic range (depending on genre).
Unprocessed signals coming from diverse sources can have relatively huge dynamic range even in normal, controlled use, well within the possibility of permanent hearing damage.
...and then someone unplugs a DI or condenser using phantom power...
