But you can also use both pickups independently, if you use the right type of output jack - the existing one may or may not be compatible, it will need to be a TRRS (with an extra ring for the battery switch) - then you need a stereo spilitter cable for the output. This has the advantages that firstly a blend of piezo and magnetic usually sounds much better than either alone, and secondly that you have a backup in place already if one of the pickups or the preamp causes trouble at a gig.
