Amazing what difference a setup makes
I bought my Faith Neptune Trembessi about 6 years ago and, for one reason or another, never took it to a luthier for a proper set up. I likes the sound of it but the action was too high which made playing certain chords and shapes a bit more challenging.
I took it to a local luthier the other week and got it back on Thursday. There was apparently a slight curve in the neck and now the action is lower, which I prefer.
It's almost like having a different guitar. Other than it feeling easier to play, it sounds different (I'm sure - unless it's just me) - sounds brighter and snappier. Ok it has new strings, but it still feels and plays like a different guitar.
  • ICBMICBM Frets: 72367
    Yes, the set-up affects the tone, often quite drastically. There is a usually a 'sweet spot' where the full tone develops but the action isn't wildly too high - although if you're unlucky, the two things aren't possible at the same time.
  • GTCGTC Frets: 263
    A decent set-up with the right strings can transform a guitar. Personally, I've never found any deterioration in tone by setting the action as low as possible to give a comfortable buzz / rattle free action.
    That's the key, but the point at which it starts to affect the tone is not always audible as obvious buzz. Once you get above that I've never found a higher action makes any difference though.
  • TimmyOTimmyO Frets: 7422
    Cool. My J45 was enormously improved (and I already liked it) when I finally got a pro setup done
    Red ones are better.
  • GTCGTC Frets: 263
    edited March 2020
    Sometimes I've thought I'd got the set-up right only to later find I was getting a weird buzz on certain string combinations around the middle of the fretboard. Usually a quick tweak of the neck relief via the truss rod is all that is needed.
  • jellyrolljellyroll Frets: 3073
      I'm keen to try a set up for myself. Am I right to think of it as a 3 step process:
    - set the neck relief
    - check the nut
    - adjust saddle accordingly
    So, if the neck relief and nut look good, I can just concentrate on the saddle?
  • icu81b4icu81b4 Frets: 368
    edited March 2020
    Agree - Makes a huge difference, even the expensive ones don't come set up correctly in my view... I'm lucky to have a really good luthier close by where I live so all my guitars get looked after by him (Eddie Green, he's written a book too)
    I have a Faith guitar in the for sale section at the moment that was set up by Eddie.
  • GTCGTC Frets: 263
    - check the nut
    That's more or less it - the secret being small adjustments at a time and patience.
    Neck relief I usually initially set buy holding the 6th string 1st and 13th fret down simultaneously - and tapping on the string around the 6th fret - adjusting the relief so there is the faintest downward movement there.
    An easy test to see if the nut slot heights need adjusting - does playing feel  a lot more comfortable using a capo?
    Then the saddle - a little at a time and patience.
    If it is an expensive guitar, you might want to buy a real cheap one on eBay to have your first go on,
    I usually set the nut height first, because it’s the one that doesn’t need to change if you later need to find a balance between bridge height and relief.
    You can check it very easily simply by fretting each string at the 3rd fret and looking at the gap between the string and the 1st fret. It should be tiny - ideally less than a quarter of the string diameter on any string, and never larger than the string diameter even on the plain strings. You don’t need feeler gauges, by eye will be good enough since if it’s that small, it’s not that critical - as long is there is at least a tiny gap.
    Thanks @GTC @ICBM
  • ESBlondeESBlonde Frets: 3590
    On the nut I tend to measure the clearance on the first fret open string to the first fretted on the third fret. I err on the slightly more side by sight and a feeler gauge for confidence (sight is better IMHO). It is possible to get well down on the saddle, but again it's hard to put material back so steady as she goes.
