Finally, the time has come to build a bass.
axisusaxisus Frets: 28339
edited May 2020 in Making & Modding
Yup, it feels like the time is right. I've barely played bass for probably over 5 years now. I switched to 4 string, but my interest waned, so I'm thinking of resurrection things by getting back into 5 string.
I'm not going to be that original. Having been massively taken by Hadrien Feraud's signature bass, I have basically nicked the shape and headstock of that (but different controls/pickups).
There aren't that many free 5 string bass plans out there (that I could find!) So I have basically drawn it up from scratch. On one hand, as a graphic designer I have the skills for that, but on the other hand, if I get things wrong anywhere then the whole thing will end up as firewood!
Anyway, here's the basic plan so far
  • Bare wood body rather than colour. Looking a bit aged rather than new.
  • Ebony or dark fretboard, white/MoP inlays
  • The controls may look a bit close, but they have to be like that as I an going to drop in an Eastman J-Retro 01 unit that I have, which is pre-spaced on a circuit board to fit a Jazz bass.
  • There will be a scratchplate but I haven't figured out the shape yet. Now sorted
And here's the drawing as it stands so far, created at 100% size. I have a big and very accurate plotter at my disposal to print it. I will probably revise the Bridge and pickups depending on what I purchase but otherwise it's mostly done. I'll be knocking up templates next.
  • EricTheWearyEricTheWeary Frets: 16297
    I did wonder if a 35" was more standard for a 5 string these days? Quick look says  Hadrien's is 34.25" ( 870 mill). Just to tighten up the low B?
  • axisusaxisus Frets: 28339
    I went with 34" as my superb old 5 string was that scale length (Fender Reggie Hamilton model)
  • HeadphonesHeadphones Frets: 992
    Thought this was going to be about Billy the Bass...
    Sounds a bit fishy.
    edited August 2020
    I knocked up a body template yesterday, not quite finished yet, still a bit of edge smoothing to do.
  • FunkfingersFunkfingers Frets: 14496
    axisus said:
    That is asking to be taken to Cort. ;)
    One thing that Fender got exactly right on the RH models was the placement of the P pickup, arguably, at the expense of the visual æsthetics of the instrument.
    Placing the pickup anywhere else messes up the sound.
    2reaction image LOL 0reaction image Wow! 2reaction image Wisdom
    Sorted the neck template a while ago, and I've been buying up hardware etc. Delano pickups, Schaller bridge, Hipshot licensed tuners. I'm still faffing about wood for neck & body ...
    edited August 2020
    New plan - the bass won't look at all like the mayones one, just the shape. It's going to be a mad paint job, probably not to most peoples taste!
  • PeteCPeteC Frets: 409
    your preparation looks so neat for this - I'm sure this is going to turn out very well.
    Watching with interest !
    I've been getting on with the bass
    Reducing fretboard depth
    Routing trussrod hole
    Making inlays
    rough cut of neck
    and shape trimmed with router/template
    edited August 2020
    Gluing body blanks. It was a right pain getting a good join. On and off over 4 evenings I was planing, scraping, sanding and I just couldn't get a usable fit! Drove me up the wall. I kept putting it aside in a mood and coming back the next day.
    Then I had an idea. I butted them up flat against each other and gave one pass across the top with an electric planer. Amazingly that did the trick in two seconds! Doh, spent a lot of time faffing for days before that ....
    I made an alu template for the tuner holes. This is the only way to go as far as I am concerned. I used to drill without a template and the result is never good enough, then it's a major faff to fix. It's a 5 string but I only need the 4 holes aligning. I just drilled the other hole in the right place without a template.
    Holes sorted.
    Reducing headstock depth.
    The body is too thick for my dad's bandsaw, and it doesn't have the best blade on, so I reduce the wood depth with a Forstner bit first.
    Surface flattened, depth sorted.
    Body shape sorted with template. Half done here. One of my router bits broke and ruined the lower horn (I had another thread about that somewhere). I salvaged it by creating a new lower horn template and making it a bit smaller. Doesn't look much different to be honest.
  • SteveRobinsonSteveRobinson Frets: 7045
    Great recovery there, the shape looks nicely balanced!
    I forgot about this thread! I do have more pix so a mini resurrection ....
    Body shape sorted
    Made a template to cut the neck pocket.
    Hole drilling fo the controls
    Control cavity routed from the back
    Ran around the edge with a roundover bit
    Neck holes drilled
    Made some pickup templates
    Routing sorted, plus bridge holes
    scratchplate paper template
    White plastic trimmed
    Cutting neck inlays
    edited June 2023
    Cutting fret slots
    Basic routing of fret marker holes
    Tidy up with Dremel
    All inlays in place. I painted the wood so that I could scratch the edges on in a way that they could be seen clearly
