Anybody had any issues running 2 subs, one mounted under each top and phase issues? I've heard that if you run 2 subs it is always best to put them together and in the centre..?
When you're inside, this matters less - room reflections will help to fill in a lot of the 'gaps' where the two sources don't sum.
I wouldn't flip the polarity (phase, but not really) on one sub vs the other - it is more likely that you will cause cancellations if you start with the two sources out of phase.. Assuming they're in the same plane (like in line with the front of the stage), the likelihood is dead centre, they will sum as the distances are the same. If you reversed polarity on one box - this summation would be cancellation.. and suddenly no sub on the dance floor!
Hissing is often caused by gaining up the Altos without driving sufficient level from the desk ..... some models have enough gain to directly attach a dynamic mic but you generally want to run the speakers at 0dB and get the level driving from the desk. Which should be 0dB or +4 and the desk should be connected to the speakers with balanced XRL's ... not 2 long guitar leads or similar. Again, you probably know this anyway so ignore me if that's the case
Although I understand the principle of single point grouping subs what most of us are using in pubs and clubs aren't really subs in the sense they tend to have a lot of poke down to around 65 - 70Hz or so but are 10 or more dB down at 40hz or lower so you don't get the cancellation because you were never producing those frequencies to any great extent to begin with. Even using 4 X HK 18" subs a side outdoors the effect isn't that noticeable on our hire PA so it easier to stack the sides
Would like to upgrade at some point and have been very impressed with my single dxr10 when dialled in right
As to stacking 2 subs on each other or putting them either side of the stage it’s up to you however do bare in mind that when stacked the bass speakers will couple and radiate bass both forwards towards the audience and backwards onto the stage, how much of this depends on how efficient your subs are. This is also the reason you see at big gigs with big sub arrays, that some of them are facing away from the audience in order to phase cancel this effect. Google cardioid sub arrays for more information
It gets even messier at the point you're into the crossover with your main boxes (>100Hz) because then there are both phase interactions and interferences, especially if things aren't time and phase aligned perfectly!
To be fair - the vast majority of my work with subs is with large quantities of double 18s or triple 21" boxes, doing complicated spaced, cardioid, gradient or other arrays!
But in small venues you can get a significantly better result by putting both subs on one side, instead of one and one. You can use a speaker pole in that side, and a speaker stand on the other..
Against that, on a non-technical level - one sub per side makes a great pole base for a top - which saves having tripod stands; much safer for the punters..
It is possible to create lobes and steer bass with arrays of subs when placed properly and applying delay to the outer cabinets but that's for big concerts and is largely wasted in the dog n duck. Use your ears and try different placements in different venues to get optimum results.
