crank, so will quite easily blow a Celestion Blue (I’ve done it!).
I recommend either the WGS G12A or Blackhawk for that amp, if you want Alnico.
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
The G12C takes ages to break in, then it really sweetens up, play it loud and for a long time before swapping out, it’s worth it.
They do a smooth cone version called the G12C/s that tames the top end straight out of the box
Rift Amplification
www.riftamps.co.uk
And thanks Chris @RiftAmps, you may be right that the G12C is just not broken in yet. Will try to be patient for a while rather than swap it out in haste!
Because just like the modern Celestion Blues the B&B actually has a 25w voice coil - they say they're 15w to keep them 'vintage correct'.
The Americana produces 20w clean, and just under 25w at full crank whereas the PR18 does nearly 30w.
Rift Amplification
www.riftamps.co.uk
I wish! Just not enough space on the control panel I'm afraid
Rift Amplification
www.riftamps.co.uk
