I moved to Canada this year and ditched all my UK gear before I left. Hence I'm currently on a very minimalist rig of one guitar (a PRS CE24) and zero amps.
Since being here I've found out there is zero second hand market for cheap gear and most stuff seems very optimistically priced- at home in London I could pick up a Peavey Bandit for under a hundred quid; here (if I could locate one) it would be triple that. I'm in a house with paper thin walls so a valve amp looks out of the question, and I won't be gigging for the foreseeable so just need something to tide me over until then. I'm also pretty strapped for cash as moving has cleaned me out pretty much. Hence I've decided on an older solid state amp rather than a newer modelling amp for the time being. I don't need loads of distortion and normally play cleaner/overdriven stuff.
So I have a pretty narrow range of options I can actually find locally- an old Yamaha DG 100 (with the motorised knobs) and a Fender Princeton Chorus both available for about 120 quid. Anyone got any experience with these or similar? I'm getting a little bored only playing unplugged...
Cheers
The Yamaha dg is my favourite amp of all time. I stopped using and sold my Mesa boogie amp after getting a dg80. Under £200 is about right, but also it’s a steal.
Only major problems are the weight, my 1x12 weighs close to 5 stone. That 2x12 will weigh approximately the same weight as the moon. Also, the motorised knobs are pointless, and if changing channels quickly is your thing, you be disappointed as there’s a reasonable drop out when you switch. I leave mine on lead i most of the time and just control it all with my volume knob and a tubescreamer. But that’s mainly because I’m lazy.
I have never tried any of the Yamaha amps, new or old, but they make a lot of quality music gear so I can only assume they're quite good at amps too.
