You need the Reactive Load with the ACE or Reactive load IR to avoid a firework display from your amp
Your amp needs to see a load...usually a speaker. But if you want silent recording, you'd need a 'load box' to replace the speaker...such as the Suhr RL...or you can get a single device to do both jobs, e.g. the Suhr RL IR
No amp...*at all*...erm, okay...you can use the ACE...but it wants a line level input signal (typical pedalboard signal might be a bit low) and ideally your pedalboard would have some form of 'amp-like' pedal on it.
I tried it with one of my amps....and it is very good.....using a dummy load....performance is much better and more what I expected...so I will use it with the amp for recording....no hum or extraneous noise on the signal either....records really well into Logic.
Glad it's going to be useful for you
