I play in a 5 piece band with 2 guitarists and a bass. The other guitarist never uses an attenuator. I have quite a few amps and attenuators and i like to experiment. I have found that playing on my own an attenuator is a great tool....def gets power stage working...but the more i attenuate the more attack gets lost in a band situation. I have one of the most expensive the fryette power station (i know its a reamper) and an older one marshall power brake....tbh with most amps i prefer the power brake but thats my opinion. More than 2 clicks with the attenuator loses so much attack it becomes pointless if using a master volume amp. I use mostly a jcm 800 or 900 and have to eq the treble way down and the mids and bass way up to get it right in a band context. Is this the consensus with everybody else or am i missing something with the attenuators?
Try just 1 or 2 clicks down and dial the amp in for that. Also, JCM800s and 900s are very bright amps so it's not surprising you need the bass and mid up high - I never run the bass anywhere other than full up on them, usually the mid at 6 or higher, and the treble and presence at 6 or lower - often a lot lower.
It’s a myth that turning it right up always gives the best sound. If you want dynamics, it doesn’t.
Playing with cranked non-MV amps is an art in itself, and relies heavily on guitar volume use and good playing dynamics. Of course you can run them on 10/10, but you need that to be the absolute maximum you will need on any song in the set, and to have the guitar volume very nearly off for most song parts.
If you’re doing it all from the amp yourself, and you don’t have enough dynamics, attenuating less and turning the master volume down a bit will help. Set the EQ to wherever it sounds good, even if you have the controls at 10 or 0.
If you really want to find out, disconnect three of the speakers in the cab, and run the amp with one click of attenuation - or set to Low power - that will put 50W (max) into a 75W speaker, which is into the range where the speaker is being driven hard enough for it to alter the tone and dynamics.
This is quite easy on a 1960 with the switching panel - disconnect the lower speaker on each side, set the cab to stereo, and then each input will give only the top speaker on each side, at 16 ohms. You might get some slightly odd phase effects from the undriven speakers at low volume, but at gig volume you probably won't notice.
(Or if you don't want to attenuate or use Low, turn off two power valves and set the amp to 8 ohms into one 16-ohm speaker.)
The Blue has unique characteristics when pushed hard, but you can't tell whether you're hearing the speaker or the amp with the AC15 since *both* are at the limit when it's fully cranked. The Vox/Blue combination has a magic to it which never quite applies when you use either of them with something else.
There is another trick you can do with an attenuator if you only need one click, too - use it as a parallel dummy load. Set the Powerbrake to the same impedance as the speaker, and turn the knob to fully off - then connect it to the amp exactly as if it's a second speaker cab, with the amp impedance set appropriately. The attenuator will then absorb half the power, but it seems to have less of an effect on the tone this way.
