To do better than that you will need to shield the sides and walls of the cavities.
Is the best thing then to get the copper adhesive and line the actual cavities rather than the scratchplate?
Also, and possibly the most important of the lot given that the pickup wires are actually shielded cable already, is to replace the white and black wires that go to the jack with a piece of shielded cable. This is often the single worst contributor to noise in a Strat.
If you're replacing the pickups with better ones which typically *don't* come with shielded cable, then tape on the pickguard and in the cavities becomes more important.
I think I read something about ground issues is you use copper insulation on both scratchplate and cavities - is that an issue?
No, that's a myth .
You'd also get a good contact to the pickguard shielding both next to the bottom tone control and at the bass end of the middle pickup, since there are pickguard screws very close by. You can guarantee it if you deliberately extend the foil over the body so one of the screws has to go through it.
I do prefer to spot-solder across the joints though - over time when a bit of surface corrosion happens, you can end up with bad contacts between the individual pieces of tape.
Forgive the no doubt obvious but how do you do the spot solder? How many joints do you need to do it on? Is it literally just a small blob of solder at each joint?
You can easily spot-solder it if you start getting noise back though.
I guess those is why so many people and companies don't do this as it's labour intensive. Shows its not "necessary," but worth doing.
