Squealing?
tekbowtekbow Frets: 1687
This doesn't sound right.
I mean, squealing, yeah theres a lot of gain flying around through a boosted crunch channel, except none of my other guitars do it apart from one which is an SSS strat.
This one is a Tele with bridge HB. I'm pretty sure there shouldnt be a hum cum squeal like that that disappears when you touch any metal part with an HB.
  • ICBMICBM Frets: 71960
    That's quite normal. If it stops when you touch any metal part then your guitar needs more shielding.
  • tekbowtekbow Frets: 1687
    Alright, guess I'm spoiled with my other HB axes, cuz none of them do that with the same set up.
    Neither'd this one until I set the pedal board up though.
    Anyways, as long as I'm in no danger of getting cooked, that's fine.
  • johnhejohnhe Frets: 189
    I’m not very technical, but that doesn’t sound at all normal to me. Not with a humbucking pickup.
    The problem is lack of shielding, not lack of humbucking - you can tell because it stops when you touch the guitar metalwork.
