7.25 neck on a body of a 9.5 radius
I’m thinking of a lovely looking 7.25 radius tele neck to go on the HH Blacktop Tele body that’s in the post. I only really need to change the bridge to accommodate this, right? Do you typically need narrower bridges to accommodate 7.25 radius necks?
  • GavRichListGavRichList Frets: 7173
    If you can adjust the height of the saddles on your bridge, you’re fine.
  • ICBMICBM Frets: 72472
    No, the width should be the same - it's only the radius which is different. As GavRichList said, if you can adjust the saddles individually - which you can on that bridge - it will be fine.
  • skinfreakskinfreak Frets: 204
    Thank you all!
