Sorted.
MototechMototech Frets: 102
edited April 2020 in Parts £
I have a Japanese Fender Telecaster Bass with one tuner bushing missing, anybody have one lying around they could part with?
  • FunkfingersFunkfingers Frets: 14430
    Do you have a photograph of the style you require?
  • prowlaprowla Frets: 4924
    There's someone on BC offering a set of bass bushings for free (cost of postage).
    Not sure of the size.
    Those look like string anchoring ferrules.
  • MototechMototech Frets: 102
    Cant attach photo, but press in, about 10mm height in total.
  • SteveRobinsonSteveRobinson Frets: 7031
    What are the internal and external diameters?
    No way to measure accurately,  but Japanese, so going to be metric. As far as I'm aware, they are 18mm inside, 22 outside.
  • ICBMICBM Frets: 72351
    Is it the same as either of these? Both 22mm outer diameter, 18mm bushing diameter, 14mm shaft bore. The one on the left is 10mm high and the one on the right 9mm.
    One on the left is identical.
    Darn - I think you're right.
    My bad...
    PM'd
