...that is the question.
My man cave is a small bedroom that was once wallpapered (plain, smooth). Before we moved in a long time ago, it was painted over in magnolia. I want it white. The wallpaper is old and is starting to lift slightly at the joins. I'm assuming it's just plaster underneath.
I could approach this one of two ways - either I get the wallpaper stripper out and steam every last bit off, fill in any accidental gouges and sand it all smooth then paint directly onto the plaster. Or.... I try to paste / sand down the raised edges of the existing paper and then paint over the top of the lot.
Would you strip it or bodge it ?
Also chips are "Plant-based" no matter how you cook them.
I was worried for a minute.
It's an old terrace, but some one has put a lot of love into it at some point and it has all been re-plastered and decorated to a high standard... Just not all to my taste.
Stripping was the easiest I have ever found it to be in any of the 4 old houses I have owned and decorated.
And yet..... There was still a surprise waiting under the wallpaper. They had removed wall lights and papered right over the top of the old wires. Leaving a hole right in the middle of the wall!
Not terrible I suppose, but not what I was expecting. It also explains the switch that doesn't do anything.
https://i.imgur.com/0Vi7OLE.jpg
There is always a surprise waiting, even when you think things are in good condition.
In every other house I have just accepted I'm probable going back to brick once I start stripping paper
Instagram
What else are you going to do in lockdown?
Wallpaper's horrible stuff, it's a breeding ground for all kinds of nasties.
