You'll still need good monitors or headphones.
Dunno about making the guitar sound like a violin or anything, it'll still sound like a guitar.
Do you maybe mean a MIDI pickup where the guitar detects what note is being played and plays that note through a synth rather than the actual audio of the string coming through?
If you just wanted it to sound like a guitar amp with guitar pedals it's easy and cheap but for the midi thing you might need a specific guitar or pickup or maybe at least some kind of hardware box.
I have tried a software solution before but didn't have much luck with it. Admittedly, I play keys too so wasn't determined to get it to work enough to put a lot of time in to.
Hope someone can help you who knows more.
Some latency, but not bad, and only monophonic.
As far as I can tell the most modern polyphonic solution is the Fishman Tripleplay (which I've not used) - about twice that.
The other solutions (Roland GK-3 pickup/GR55 or SY-1000) are pretty costly.
It works fine, but there's alway just enough lag in my experience to mean you can't go above a certain speed. Plug it into a muted trumpet and it's pretty good abstract Miles Davis, but you're not going to be able to do Dizzy Gillespie.
You'd need a guitar to iPad interface, but those are cheap enough. You can then use any guitar.
There are various sounds built into the app, but not violin (as far as I can see), so then it depends on whether violin sound is a critical requirement, or whether the other sounds in the app are sufficient.
https://www.guitarguitar.co.uk/product/pxp200316357264001-4568412--godin-xtsa-sunburst-pre-owned-17383165
If you're not planning on recording anything complex or busy you'd scrape by with a keyboard and post editing out any mistakes by changing pitch of recorded notes
