So last night I was playing and I clicked on the Hummingbird pedal...and it wasn't working.
every other pedal on the board works fine and the when the hummingbird is on everything else is working as normal too.
i played around with the knobs and noticed that the depth knob was working as a reverse volume type effect and the level knob was working as it should...but there was no effect (tremelo) besides that.
not sure whats going on with it...maybe the circuit is screwed? its become so true-bypass that there is no tremelo anymore.
any advice would be very helpful.
I said maybe.....
"Chances are good that the jfet (2n5457, right in the center of the PCB) has gone bad"
2n5457 are easily available, i might even have a few in the shed. (but i'm fairly snowed under with jobs so not volunteering to swop it, unless you get really stuck with no takers !)
I said maybe.....
