If your pc can't handle thre number of fx used when recording or mixing, increase thre sample rate and it will be fine. I tend to record at a low sample rate and mix at a larger rate when all thr tracks and fx are going on.
________________________________________________
Telecaster American Deluxe, Cornell Romany amp, without the talent to use them properly
Fwiw this was running Reaper on a low-spec iMac.
For the demos i'm making, I have Ezdrummer, DI bass with Bias Amp and four or six guitar tracks with minimal plugins. Actually, each doubled track is bussed to a further channel with simple EQ and compression.
Sorry not used it (or any daw) for years!
They are pretty good and will be able to help.
I found this solution for a 2i2 that was clicking on Gearslutz.
It might work:
Steps to do this:
1. Unplug the Scarlett 2i2 (in your case the 6i6) from the usb port
2. go to Mac HD > System > Library > Extensions and delete FocusriteUsb2Audio.kext
3. Empty your trash can
4. Shut down your computer
5. Plug in the Scarlett 2i2 (in your case the 6i6)
6. Boot your computer
Sounds more like the thing. If there's no joins at the pops though it won't be that so not much help
2) Check the System processes (is there and equivalent for a Mac?). On a previous old computer I once found a process that was occasionally using significant CPU which coincided with drop outs. So, after checking it was safe to do so, I disabled that process.
3) Set my system to Adjust for best performance, rather than let Window choose. Is there an equivalent for a Mac?
4) Run a utility to check my systems ability to handle audio. But before downloading and running anything I always do a significant amount of Googling to check it isn't dodgy. In the past, on an older systems, I've used DPC Latency Checker and, more recently, Resplendence Latencymon. I think they only work for Windows, but you might be able to Google to find a Mac alternative.
Great thanks, will give it a go. I'm also going to make sure all the operating systems are bang up to date.
