Subtly Ageing a Tru-Oil / Wudtone Neck
I have a Wudtone finished Strat body that looks a little aged.
Also a lovely newish AllParts neck that I wish to stain amber and then finish with Tru-Oil (or Wudtone) for consistency.
Once finished would you experts give me some pointers please on how to age the neck in a subtle manner to match the body...?
https://i.imgur.com/j0PfpmK.jpg
  • mrkbmrkb Frets: 6947
    I just rub a bit of pencil lead dust over the neck before tru oiling, just adds a bit of dirty looking can be built up to taste. I tried the wirewool and vinegar mix (over tea) method and I think looked way too dark and a bit crap, ended up sanding most of it off.
    Karma......
    Ebay mark7777_1
  • jaymenonjaymenon Frets: 837
    Thanks Mark - that's a great idea...
    edited April 2020
    in order to allow the stain to ‘take’
    Do I need to remove all of the oil down to bare wood?
    Or is that enough to remove the superficial gloss layer? i.e. just break up the surface...?
  • SargeSarge Frets: 2429
    Yep. Stain won't take on anything but bare wood
  • WezVWezV Frets: 16822
    If it's a subtle ageing, you can tint tru-oil with spirit based stains
    Tru Oil that has already been applied and has cured?
    No, you would mix it and apply over, but it will give the look of aged lacquer
    Gonna be much harder to strip fully for a direct stain
    I’m sorry WezV if my question wasn’t clear.
    So I would mix stain & tru oil and apply the mixture over the already dried and cured tru oil on the neck?
    Yes, although I would sand the existing tru-oil to key it first
    Do a few light tinted costs, then do a few of pure tru-oil to seal it all in.
    Antique pine gives a nice amberish tint, but you might want to mix it with something a bit darker if it seems too yellow
    Okay guys - tru oil removed.
    I'm going to give it a wipe down with 100% acetone to ensure that I remove all invisible traces of the tru oil finish - and then commence staining :)
    Okay guys...
    I’ve applied 4 coats of Wudtone Aged Vintage Yellow stain - and it’s turning a nice brown colour (which I must admit I prefer to yellow).
    The next step would be to apply the colourless top coat.
    if I wanted to create some subtle ageing, would I do it now, before applying the top coat?  And how would i do that?
    Raw:
    [Imgur](https://i.imgur.com/i17l2Zm.jpg)
    After 4 coats of Aged Vintage Yellow Stain
    [Imgur](https://i.imgur.com/VCOYB0o.jpg)
