After selling my Jazz Bass on arrival of the Hofner, I realised I liked playing long scale occasionally and as I hadn't had a P bass for a very long time decided to look for one. The older Japanese Squier Precision's are now v expensive but I found a good looking Japanese Fender Bullet Bass from 84. A bit skanky on arrival but after dismantling, giving it a good clean and soaking the rusted bridge in WD40, it came back to life. Now strung up with half wounds -
Pickup (from the Mustang?) is quite low output but sounds nice and my SoldGoldFx optical comp absolutely shines through it for some reason. The necks on these are really easy to play.
There was the 'Strat' guitar version from this series in the shop recently, with similar plain-top pickups, it was one of the best-sounding 'Strats' I've ever played.
I've strung it with half wounds, the first time I've used them and they're ideal for a finger picker as they add a bit of zing to the sound. Together with the FT-2 that I scored recently from @yorkio , I can now mimic a pick player quite convincingly (well, sort of).
If anything, it reminds me of a Tele, maybe the headstock was a nod in that direction; it has a similar sound to a 6 string Tele moved down an octave.
The only fault I can detect is that the E string is nudged over too far. The bridge is lined up correctly and the string anchor point is in the right place, it's just that the saddle wants to drift inwards and as its a notched affair there's little room for correction. I've ordered up some threaded saddles which I'm hoping will cure it. The neck is a little too wide at the top end but that's a grief I have with most basses ('cept the Hofner, that's perfect!).
Here's a pic of the pickup underside, perhaps it helps identify it -
According to the Klaus Blasquiz book, the Bullet Bass pickup is 11,500 turns of 42GA Polysol wire per coil, 4.8K per coil. Expect a reading between the black and yellow conductor connections of approximately 9K Ohms.
A typical Precision Bass is 11K.
A lot of the ones I’ve seen do seem to have been upgraded with a P bass pickup. As I don’t play in a band I’ve no need for the additional thump and I quite like the lighter tone. Plus, it seems a shame to alter one of the few to have made it unscathed.
https://nordstrandaudio.com/products/nm4-mustang-replacement
I like the approach on the Squier Mikey Way signature Mustang Bass - an EMG35-sized soapbar pickup. The sound of the instrument could easily be changed by installing any other pickup of the same dimensions.
It's a moot point; I like the sound it currently has and don't feel the need to change it for anything else.
BTW. When the bass arrived, it shipped in an old Hofner bass case, the exact model case for my other recent acquisition, the Hofner 185. It must be fate.
The smartest option of all is probably to do nowt. I would not be surprised if the output from the stock Bullet pickup is in the same ballpark as your belovēd Höfner. Your amp control settings can remain the same.
