Why is POD Go $200 cheaper than HX Stomp?
Here's what HX Stomp has that POD Go doesn't: A more powerful DSP (450MHz vs. 400MHz), dedicated MCU, MIDI In/Out/Thru, stereo ins, parallel paths, A/B and crossover splits, multiple amp blocks, multiple IR blocks, multiple cab blocks, dual cab blocks, 2048-point IR loading (POD Go truncates IRs to 1024 points), two separate mono effects loops, separate L/R return jacks/Aux In, 8 channels of USB vs. POD Go's 4, Distortion > Clawthorn drive, Distortion > Tone Sovereign, Delay > Cosmos Echo, Pitch/Synth > 3 OSC Synth, all stereo distortion/pitch/synth/dynamic blocks, all mono EQ/mod/delay/reverb/filter blocks, fully dynamic DSP allocation, 8 seconds of delay (vs. POD Go's 4 seconds), 60 seconds of looping (vs. POD Go's... 24 seconds? I forget), two variable impedance circuits (POD Go is fixed at 1M Ohm), patented 123dB dynamic range inputs (IIRC, POD Go is ~112-113dB), cap-sense switches, momentary stomp functionality (press-hold shortcuts preclude this), Clear Block, Clear All Blocks, preset compatibility with Helix Floor/Rack/LT/Native, a $300 discount on said Helix Native, metal knobs, an ultra compact cast aluminum enclosure that fits on any pedalboard (vs. POD Go's sheet metal and polycarbonate chassis), and any future features that apply only to Helix/HX boxes—for example, POD Go likely won't have enough DSP to accommodate polyphonic pitch models.
A lot of the above stuff is what makes a product "HX" or "Helix." Although it has nearly all the same amps and effects, POD Go is a different line for a different customer.
There's no strategic or sneaky reason for POD Go's price. As with all our products, it's based on hitting a target profit margin based on cost of development, parts, and labor.
Go nuts.
https://www.thegearpage.net/board/index.php?threads/line-6-pod-go.2113195/page-28
Page 28 is where the stuff above came from.
i like simplicity of the Go, I wouldn’t miss most of the missing features, only thing I’d be worried about is the input, less dynamic range and fixed OHM, there’s numerous threads about getting the input right on the Helix for it sound good.
For what its worth, the Stomp manual is actually really good.
https://uk.line6.com/data/6/0a020a4010c935bb66a4c0c44f/application/pdf/HX Stomp Manual - English .pdf
Page 41 has the global in and out settings explained.
Pod Go is designed to be a portable one stop shop package for gigging players that want something that is much simpler to use and can out of the box sound great without needing to have a better understanding of studio type tone building with more complex patches and chains and connectivity options.
For my needs the Pod Go sounds like it could be just what I need. A simple to use lightweight compact all in one gigging tool that sounds great and can be used in 3 different modes. If each block has an amp, cab, EQ, wah and volume that's brilliant for me because those are the core things I'd want in a gigging patch.
I can still have any amp, cab, wah, or EQ I want. On top I have free rein with 4 other blocks e.g. a modulation, reverb, delay and distortion. I don't really need anything more. It has a single button operation for patch up/down and for switching modes.
I think a lot of folk get impressed at the spec of things like Helix and Hx Stomp but in reality they'd never use half the features. Kind of like buying a state of the art dishwasher or washing machine with umpteen functions, options and programs...But in reality they'd only ever use only a couple of programs and have spent more money for things they don't need. It's like 'I'll go for the more advanced version just in case I need it and it's nice to have the extra options'...But then never use them.
Me, I like things that are simpler to use and do the job I need so for me, of the two, it's Pod Go all the way.
For example - my brother has a Mexican Strat he's owned since he was 15 and a Peavey bandit, plus a few cheap pedals I just gave him rather than flogging for pennies on eBay. He doesn't know what a 'cold' biased amp is, or what a variable impedance circuit will do to a Fuzz, or the difference between line and instrument level, or what a King of Tone is. He would be the target audience for the Pod Go - someone who's never done digital guitar before but wants something that will last and isn't old tech. Casual or gigging musicians in covers bands wanting to go direct too.
I don't get why the two are being considered against each other? Surely anyone considering both just needs a Stomp with an external footswitch?
But the more I think about it, I'm now less sure if 4 optional blocks is going to be enough. Eg if I add a distortion, modulation, delay & reverb I have no room for a compressor. And even if 4 blocks are OK, I then have no room for a looper - so looper usage is limited as you can't use it for any patch with more than 3 optional blocks. I do now think the Pod Go needs 6 optional blocks.
I'm also not entirely sure why Line 6 went down the route of 'fixed' 5 blocks. Why not have an option to release at least some of these?
I have considered trading in my Stomp and replacing it with a go, but I think for the ££ shortfall between a 2nd hand Stomp and a brand new Go it makes more sense to just get a cheap external double-footswitch and mini-exp pedal to attach to the Stomp. Maybe in 6-12 months time when they start to come on the used market....
