Never tried the SPB-1 but it must sound better than the McDonald’s hamburger that some people seem to be using.
My recollection is that the SPB-3 Quarter Pound pickup has excessively extended high treble and bass response, causing it to sound overblown and artificial.
@Funkfingers the mex pickup was the newer alnico rod type.
Ruins what is needed for a P tone.
I am not knocking the FHM bridge. On the Fender Dimension Bass, it sounds fine.
I went for the spb1 and the fender original as I wanted classic vintage p bass. Been reading good reports on the emg geezer butler but the Seymour was reduced to £63 so that swayed my decision! But may be worth a look if you want a rockier sound. I think they’re based around the pickups in Bobby Vega’s ‘P’.
i think the Seymour has a softer low end and pushes the mids a bit more. It’s got that vintage vibe and that’s what I was after!
something I’m not liking though is the buzz that’s generated when my thumb touches the pole pieces. It’s not specific to this pickup as this also occurs on my USA precision with the fender original pickup and previously with the quarte4 pounder. Is there anything that can be done to stop this? I didn’t notice it with the mex pup, but I think that poles on that sat just below the surface of the cover. Any thoughts
if the buzz is normal then I will rest easy!
