Which is more or less true. For the most part, they are dirty little animals with huge brains and no pulse.”
Hunter S Thompson
Where there certain aspects you were particularly interested in or wanted to know about?
Hunter S Thompson
I briefly owned a TK Metropolitan, I think because I much preferred the Lead channel on it and that you could balance up both channels volume-wise really nicely but it was too big for my needs. I was looking for a MK2 or a 20th Anniv (which I marginally preferred for some reason) when the MK1 came up privately. I went to have a look and it was immediately apparent it wasn't a "normal" MK1. Just sounded fuller and less icey. It's got an extra valve for one thing. Being a prototype it looks slightly more more primitive than a production model, hard to explain but a bit more of a box I suppose with cheaper looking tolex. Having said that, I don't really mind the treble in the MK1 (as others seem to) and would happily use one. It wouldn't surprise me if it sounded better than a MK2 in a band context but I've never been able to the comparison.
For me the Clean channel on either of the derivations is about as good as you can get from any amp.
Hunter S Thompson
Hunter S Thompson
Hunter S Thompson
Hunter S Thompson
There's no doubt he's got that Clean/Blackface sound nailed and then some. I'm with you that the drive and tweed channels are harder to like but I've struggled with that with all the amps I've tried so far. It's a journey?...
The Imperial seems to have most of that solved as well and, of course, looks stunning.
https://youtu.be/Dj2H4c3utSA
The MK1 have considerable treble.
