Quick coil split wiring help plz gents
MLten80MLten80 Frets: 162
edited May 2020 in Making & Modding
Morning all
Just wired up my guitar & the bridge coil splits to the inner coil.. I wanted outer
So, I'm trying to avoid ripping it apart again & flipping the pickup (I've fitted them with the baseplate wire holes closest to wiring channels so I'm not sure the wires would be long enough when flipped)
Pickup is a dimarzio tone zone....Can I just switch the red (switch + ) & green wire (pot ground) on the bridge pickup???
 Or am I going to end up with out of phase shyte going on?
Cheers as usual in advance for the n00b advice  it's a minor annoyance but might as well try to sort it
  • ICBMICBM Frets: 72579
    Reversing the red and green will put the pickup out of phase with the other one.
    If the split connection from the switch goes to ground, connect it to the pickup hot instead.
  • MLten80MLten80 Frets: 162
    Thanks mate, I'll give it a whirl later  :)
