This may be a dumb question - luckily I have no shame
Just took possession of a Mesa Mark V:25 (thanks
to @Jalfrezi of this parish). It has the Mesa CabClone built in. The CabClone DI output socket is XLR (M) and the manual says to use a regular balanced microphone cable to connect to your interface.
I'm going to be going ffrom the CabClone into my Scarlett Solo interface. The Solo has a balanced XLR mic input and a line/instrument input. So my question is, which Solo input should I use - or does it matter? The reason I'm a little confused is that on the Mesa CabClone standalone unit there is a control which allows you to set the output to different specific levels "from MIC (-30dB) to INSTRUMENT LEVEL (-10dB) to Pro LINE LEVEL (+4DB)". With the built-in CabClone in the Mark V:25 head, that control doesn't exist. Instead, the manual says that "the CabClone circuit gets its feed from the SPEAKER Output" and that because "the CabClone circuit is passive, there is no dedicated Output Level Control, so the Channel MASTERS and the MULTI-WATT Power Select switches will determine your send level strength at the CabClone D.I. Output." This leaves me wondering whether if I connect the CabClone DI to the Solo XLR input, I might be in danger of overloading it with a line level signal.
Any advice on this would be much appreciated.
You dont need a hot signal, clip gain can increase signal in daw if needed, but you can't get rid of a clipped signal. Focusrites are a bit sensitive to level-try to get the light to glow amber , and then back off slightly. Try to get a setting that works and then mark it for future ref.
